PolyGrind NT-US Grinding Fluid
The demand of the tool grinding industry for high-performance grinding fluids with excellent air release and non-foaming properties led to the development of PolyGrind NT-US from oelheld. Benefits are elevated grinding performance, superior surface finish, improved wheel life with less redressing, enhanced filtration capabilities with higher flow levels and excellent temperature stability, according to the company.
PolyGrind NT-US was designed for a multitude of grinding applications, but especially grinding of tungsten carbide. Flute grinding, external grinding, profile grinding, saw blade grinding, insert grinding, aeronautical, medical and wear parts can easily be ground with PolyGrind NT-US. PolyGrind NT-US is for use on tungsten carbide, HSS, steel, PCD, CBN, cermet and ceramics.
  • ceramics
    ceramics
  • cubic boron nitride ( CBN)
  • grinding
  • high-speed steels ( HSS)
  • sawing machine ( saw)
  • tungsten carbide ( WC)
    Intermetallic compound consisting of equal parts, by atomic weight, of tungsten and carbon. Sometimes tungsten carbide is used in reference to the cemented tungsten carbide material with cobalt added and/or with titanium carbide or tantalum carbide added. Thus, the tungsten carbide may be used to refer to pure tungsten carbide as well as co-bonded tungsten carbide, which may or may not contain added titanium carbide and/or tantalum carbide.
