In the Port Sequence Valves
Save time and money by reducing your design time and deep hole drilling! They allow a single circuit to feed up to a dozen individually sequenced devices. These valves install directly into the device port and can be individually adjusted to time your clamps.
April 15, 2021
Vektek's In the Port Sequence Valves have totally changed the need for difficult multiple circuit deep-hole drilling and complex circuit design. Save time and money by reducing your design time and deep hole drilling! They allow a single circuit to feed up to a dozen individually sequenced devices. These valves install directly into the device port and can be individually adjusted to time your clamps.
Three pressure ranges available with adjustability within each range. These sequence valves work with flange manifold mounted Vektek Port Ready devices and can be added after "design and build", saving the day!
