Portable Tramp Oil Separators
Eriez HydroFlow Portable Tramp Oil Separators, including a high speed, manually cleaned disc bowl centrifuge, feature a compact, mobile design to provide metalworking plants with true, high speed centrifugation.
Eriez HydroFlow Portable Tramp Oil Separators, including a high speed, manually cleaned disc bowl centrifuge, feature a compact, mobile design to provide metalworking plants with true, high speed centrifugation. Completely assembled on wheels, these powerful units are designed to extract fluid from both small individual machine sumps as well as larger central systems.
Eriez HydroFlow Portable Tramp Oil Separators easily remove both free and emulsified tramp oils to 0.5 percent or less and particulate matter to 5µm nominal in one pass on any stable coolant or cleaner, providing clean and reusable coolants and cleaners. The resulting benefits include extended life of coolants and cleaners, improved machining and longer tool life, according to the company.
The mobile recycling platform allows fluid recycling to be taken sump side for more efficient use of machine up-time. Operators simply drop two hoses into the machine sump and start the centrifuge. Tramp oils are effortlessly removed while the machine tool continues to run.
Eriez HydroFlow Portable Tramp Oil Separators offer an array of features for hassle-free operation. The bowl dismantles easily for cleaning and the machine automatically shuts off when the tank is full. A built-in clean fluid centripetal discharge pump, air pump and floating skimmer for feed and quick disconnects on feed and discharge all come standard. Self-cleaning units are also available.
