Paul N. Gardner Co. Inc. (GARDCO) offers the PosiTector surface profile gage.
The gage has the following features:
Measurement rate of over 50 readings per minute — ideal for quickly and accurately measuring
Large surface areas. Large, easy-to-read, graphics LCD
Enhanced one-handed menu navigation RESET feature instantly restores factory settings
Solvent, acid, oil, water and dust resistant — weatherproof
60 degree angle tungsten carbide tip for long life and continuous accuracy — field replaceable
Rugged, outdoor/indoor instrument — ideal for field or shop use
Shock-absorbing, protective rubber holster with belt clip and wrist strap
Two (2) year warranty on body and probe
Built-in temperature compensation ensures measurement accuracy
Certificate of Calibration showing traceability to NIST included
Glass Zero Plate and metal shim included
Conforms to national and international standards including ISO and ASTM
Universal gage accepts all PosiTector 6000 (coating thickness), SPG (surface profile) and DPM (environmental) probes
30 degree angle interchangeable probe tip available for special applications
Selectable display languages
High Contrast backlit display for bright or dark environments
Flip display enables right-side-up viewing
Uses alkaline or rechargeable batteries (built-in charger)
Continually displays/updates average, standard deviation, min/max thickness and number of readings
HiLo alarm audibly and visibly alerts when measureents exceed user-specified limits
USB port for fast, simple connection to a PC and to supplycontinuous power
USB cable included USB mass storage — stored readings and graphs can be accessed using universal PC/Mac web browsers or file explorers
No software required
PosiTector.net — a free web-based application offering secure storage of thickness readings
Software updates via web keep your gage current
Every stored measurement is date and time stamped
- calibration
calibration
Checking measuring instruments and devices against a master set to ensure that, over time, they have remained dimensionally stable and nominally accurate.
- tungsten carbide ( WC)
Intermetallic compound consisting of equal parts, by atomic weight, of tungsten and carbon. Sometimes tungsten carbide is used in reference to the cemented tungsten carbide material with cobalt added and/or with titanium carbide or tantalum carbide added. Thus, the tungsten carbide may be used to refer to pure tungsten carbide as well as co-bonded tungsten carbide, which may or may not contain added titanium carbide and/or tantalum carbide.
- web
web
