Power-Feed+Mini
Power-Feed+Mini
Ingersoll Cutting Tools' Power-Feed+Mini high-feed cutter accepts double-sided, four-edge inserts.
Ingersoll Cutting Tools' Power-Feed+Mini high-feed cutter accepts double-sided, four-edge inserts. The through-coolant cutter bodies are made of premium alloy steel, according to the company. The tool is reportedly effective when high-speed roughing at light DOCs.
