Power-Phoenix Drills
Building on the success of the Phoenix high performance drill from Sphinx, BIG Kaiser has introduced the new Power-Phoenix extra long high performance drill series.
Building on the success of the Phoenix high performance drill from Sphinx, BIG Kaiser has introduced the new Power-Phoenix extra long high performance drill series. The drills are designed for optimal performance in deep hole applications in steel, stainless steel, cast iron, aluminum and titanium.
Power-Phoenix drills feature a 137-degree point angle and four-margin geometry (above a 2.0mm diameter) for stability, ensuring a straight hole even in deep drilling applications. A unique point grind ensures consistent chip formation, while specially designed polished flutes allow for rapid chip evacuation. Through-coolant capability is standard, and the Power-Phoenix was designed to perform with even low coolant pressure down to 290 PSI (20 bar).
"These features, plus a state-of-the-art, wear resistant Helica coating, make the Power-Phoenix the ideal high performance drill of deep hole applications," says Mike Bojanowski, BIG Kaiser assistant product manager for the Sphinx drill line.
The diameter range available is 1.0mm-12.7mm for the 16xD version, and 2.0mm-10.0mm for the rest of the drill series: 20xD, 25xD, 30xD.
