Powermax125 Air Plasma System
Hypertherm announced the launch of the Powermax125, a new cutting and gouging system.
Hypertherm announced the launch of the Powermax125, a new cutting and gouging system. The recommended cut capacity for the new system is 1 ½ inches at speeds of up to 18 inches per minute, though it can sever metal more than 2 ¼ inches thick if needed. The system is also strong at gouging, capable of removing more than 27 pounds of metal an hour, while a full 100 percent duty cycle guarantees the system can easily hold its own in demanding round the clock work environments.
"The Powermax125 provides welders and fabricators with unprecedented power for a portable air plasma system," said Erik Brine, product manager for Hypertherm Powermax systems. "Patented technology and careful engineering have resulted in a very efficient system that delivers more energy to the torch than higher amp competitive systems."
Hypertherm estimates consumables for the Powermax125 will last up to four times longer than competitive systems in this amperage range. In addition to lasting longer, specially designed consumables are available for improved drag cutting, gouging, thin gauge cutting, and automated cutting. Other benefits of the Powermax125 include cut speeds five times faster than oxyfuel on ½ inch mild steel, better cut quality than oxyfuel for less time spent on secondary operations, more torch options than competitive systems so owners can choose the right torch for their particular application, and SpringStart technology for consistent starting and a more reliable torch.
The Powermax125 comes standard with Smart Sense technology which performs two important functions. It automatically sets air pressure for the best cutting and gouging performance, and turns off power to the torch when the electrode is used up, protecting both the torch and work piece from damage.
