»powerShrink« Inductive Heat Shrinking Device
ZOLLER »powerShrink« is the inductive heat shrinking device for HSS and hard metal tools, with which you can considerably reduce the fitting times in your manufacturing: In max. 10 seconds your tools are heat shrunk, cooled after just 40 further seconds and are ready for production.
January 2, 2019
ZOLLER »powerShrink« is the inductive heat shrinking device for HSS and hard metal tools, with which you can considerably reduce the fitting times in your manufacturing: In max. 10 seconds your tools are heat shrunk, cooled after just 40 further seconds and are ready for production. The precise time to heat and cool depends on tool diameter.
The ZOLLER »powerShrink« is easy to use, thanks to a turntable which allows quick and easy exchanging of different holders, and a quick heat shrinking and cooling process. The modular design allows for individual adjustments to match your specific needs, and you benefit from the high degree of rotation accuracy, long service life and reduced tool expenses.
