![PR17 Series Insert Grades PR1725 / PR1705 PVD Coating for Small Parts Machining](/sites/default/files/styles/product_image/public/product_images/76f28d00-1ea9-4bd9-83c4-557a5c1bde7e.jpg?itok=kOAPQasp)
New PR17 Series insert grades use Kyocera's newly developed MEGACOAT NANO PLUS technology which provides excellent wear resistance for longer tool life and a high-quality surface finish.
PR1725
Great for machining steel and stainless with a wide range of chipbreakers available.
PR1705
Excellent wear resistance and high precision machining of free-cutting steel.
SKS Chipbreaker
New SKS chipbreaker for finishing with excellent chip control and surface finish.
- chipbreaker
chipbreaker
Groove or other tool geometry that breaks chips into small fragments as they come off the workpiece. Designed to prevent chips from becoming so long that they are difficult to control, catch in turning parts and cause safety problems.
- precision machining ( precision measurement)
Machining and measuring to exacting standards. Four basic considerations are: dimensions, or geometrical characteristics such as lengths, angles and diameters of which the sizes are numerically specified; limits, or the maximum and minimum sizes permissible for a specified dimension; tolerances, or the total permissible variations in size; and allowances, or the prescribed differences in dimensions between mating parts.
- wear resistance
wear resistance
