Presto Black Blackening System
Manufacturers needing immediate corrosion protection on small quantities of parts can get it with all of the quality of larger finishing systems using Birchwood Technologies' Mini PRESTO BLACK line. The BK-1 line is a low-cost alternative and/or substitute for large scale finishing. This mini PRESTO BLACK room-temperature blackening system for iron and steel from Birchwood Technologies is great for small production operations that require robust corrosion resistance and galling protection on critical surfaces for machine components.
April 27, 2016
The PRESTO BLACK process produces a virtually nondimensional coating of less than 0.5 micron thickness and is ideally suited for components that require a black finish for visual appeal and rust protection. PRESTO BLACK is a short 15-minute process that eliminates the hazards of the hot oxide process by operating at room temperature of 70°. It provides high corrosion resistance and is tested for up to 800 hours humidity exposure when sealed with an appropriate rust preventive.
PRESTO BLACK is used effectively on hot rolled steels, alloy steels, tool steels, as well as cast iron, forged steels and powdered metal. It protects the underlying metal itself from galling and deformation.
The PRESTO BLACK BK-1 system contains seven tanks and covers, hot-plate (for heated cleaner), plus all the chemicals needed to operate a 5 gallon blackening line. This includes 1 gallon of Presto Black MKP, 1 gallon of Presto Black RPL, 5 gallons of Dri-Touch Plus IRP3 water displacing sealant and complete easy to follow instructions.
  • corrosion resistance
  • alloy steels
    Steel containing specified quantities of alloying elements (other than carbon and the commonly accepted amounts of manganese, sulfur and phosphorus) added to cause changes in the m…
  • tool steels
    Group of alloy steels which, after proper heat treatment, provide the combination of properties required for cutting tool and die applications. The American Iron and Steel Institut…
