PRODUCTO Process Cleaners
September 13, 2013
CIMCOOL Fluid Technology introduces five new cleaners to the market. The new PRODUCTOTM process cleaners have provided up to 44 percent in cost savings with extended sump life, improved corrosion protection, as well as better cleaning capabilities, according to the company. CIMCOOL continues to deliver significant cost reductions with the higher production rates these products can deliver.
This new technology offers five versatile products with cleaning capabilities that were previously difficult to obtain with non-caustic pHs. In addition to having non-caustic pHs, all five products are silicone free, have soft, non-tacky residues, and will clean and protect in one step. They are backed by world class service that can ensure optimal cost savings in a plant.
These new products are currently being used in customer operations and have proven that they are industry leading performance cleaners. These are multimetal, multifunctional cleaners that outperform leading competitors. Customers have already benefited from the improved cleaning capabilities, extended sump life, lower foam, and improved in process corrosion protection offered by these new process cleaners.
New PRODUCTO process cleaners include:
PRODUCTO SP-787, a multimetal safe, ambient temperature cleaner that is low foaming under high (300 to 10,000 psi) spray pressures. It is oil rejecting for extended sump life.
PRODUCTO SP-217, a spray cleaner for heavier soils. SP-217 has enhanced microbial control making it ideal for extended sump life under challenging conditions. It has also proven to be twice as effective as traditional spray cleaners in removing tougher soils.
PRODUCTO SP-535, is the company's most versatile cleaner as it is low foaming under ambient temperature and high pressure spray (300 to 10,000 psi) and also effective under lower agitation cleaning operations. It works in dip and immersion operations while maintaining a non-caustic pH. It also leaves behind a spot free finish.
PRODUCTO SP-603 contains unique hybrid emulsification properties for optimal part and sump cleanliness. This product temporarily emulsifies oils during the cleaning process to prevent redeposition onto cleaned parts and, with time, rejects oils to extend sump life. It is an ideal heat treat cleaner.
PRODUCTO SP-530N is designed for the bearing industry and proven to be a heavy duty cleaner, does the same job in half the time as competing products. It emulsifies oils for optimal part cleanliness and leaves parts with a spot free finish.
PRODUCTS
11/20/2024
10/23/2024
10/23/2024
