Prototyp Supreme MB265 and MB266 Milling Cutters
September 01, 2014
Walter has introduced the Walter Prototyp Supreme MB265 and MB266 solid-carbide milling cutters, two new milling tools that boost productivity due to their high metal-removal rates, while also increasing process reliability thanks to design features that act to enhance stability while simultaneously decreasing the likelihood of microfracturing.
In keeping with its practice of continuous product improvement, these two new mills replace and expand the technical capabilities of Walter's Sky-tec milling cutters. One of the key design features of the new mills is their coolant strategy. The conventional approach with this type of tool is to have both axial and radial coolant exits. However, this approach tends to make the tool less reliable, largely because radial exits are produced by an EDM machine, often leading to microfractures.
With the Supreme MB265 and MB266 careful engineering of the axial coolant exists has allowed the radial exits to be removed, eliminating this problem. In addition, both of these new milling cutters feature V-cutting edges that result in more ramping angle as well as one cutting edge to the center.
The new solid carbide milling cutters are engineered primarily for use with the ISO N material group which includes alloys of wrought aluminum, cast aluminum, and magnesium, as well as bronze and brass. Applications include shoulder milling, slot milling, interpolation milling, and plunge milling in general metalworking as well as aerospace. The Supreme MB265 is available in grades WJ30UU (uncoated) and WJ30CA (CrN coated). The Supreme MB266 is available in grade WJ30UU (uncoated).
  • alloys
    alloys
  • coolant
  • gang cutting ( milling)
  • interpolation
    interpolation
  • metalworking
    metalworking
  • milling
  • plunge milling
    plunge milling
    Highly productive method of metal removal in which an axial machining operation is performed in a single tool sequence. The tool makes a series of overlapping, drill-like plunges to remove part of a cylindrical plug of material one after another. Because of the increased rigidity of a Z-axis move, the tool can cover a large cross-section of material.
Additional Products from Walter USA LLC
Because of the ground chip breaker on these inserts, the inserts are handed (left hand and right hand insert), but these are standard ISO shapes and sizes- so they are held in conventional ISO turning holders. The inserts also use ‘M’ or maximum material condition tolerance on the corner radii of…
Walter expanded the TC630 Supreme product range to include UNJC4 to UNJC9/16, UNJF4 to UNJF9/16 and MJ3 to MJ10 thread sizes. Optional internal coolant is available for thread sizes starting from MJ4, UNJF8 and UNJC8 to provide effective chip removal on deep threads.
The Paradur® Ti Plus taps are for threading blind holes with a geometry specially developed for machining titanium alloys with a tensile strength of at least 700 N/mm2 using emulsion instead of oil. The Prototex® TiNi Plus tap is effective for through-hole threading. Walter specially developed the…
The M5250 cutter is effective for milling steel, cast iron, stainless steel, aluminum and other non-ferrous metals (ISO P, K, M and N workpiece groups), as well as materials with difficult cutting properties. Unlike other full-effective helical milling cutters, the XTRA∙TEC® XT M5250 can also be…
The TC685 Supreme cutter is a left-hand cutting tool that features a 15° helix angle for excellent chip removal. Cooling with compressed air makes it possible to achieve maximum tool life in materials harder than 50 HRC. Additionally, internal coolant delivery is available for tools that create the…
MA230 Advance milling cutters adapt to most ISO materials and milling approaches. The extensive range includes options like corner radius, corner chamfers, reduced neck, and unequal helix. The helix pitch is meticulously aligned with the number of teeth, ensuring unmatched running smoothness. Your…
The MC166 Advance solid carbide milling cutter with increased core stability compared to a conventional tool core ensures a consistently reliable machining process even in unattended operations. A differential pitch provides optimum operational smoothness and significantly extends tool life.
The holders accept CCGT3xx, DCGT3xx and VCGT2xx indexable inserts and provide a high level of indexing accuracy even when turning parts with tight tolerance specifications. The short head dimension enables short clamping and high stability. The shank dimensions are 12 mm × 12 mm and 16 mm × 16 mm.
With the ability to cut blind-hole threads up to 3.5 × DN, the TC130 Supreme tap is targeted for applications in general mechanical engineering and the energy industry, such as for threading wind turbines. The tap is suitable for threading steel and cast iron (ISO P and K workpiece groups). Also,…
Both WKP01G and WPP05G grades are ideal for continuous cutting and occasional interrupted cuts in high tensile materials (approx. 280-410 HB or 130-200 ksi). Ideal applications include large-scale production of components for the automotive and energy industries, such as gearboxes, gears and rotor…
PRODUCTS
11/20/2024
10/23/2024
10/23/2024
