Sumitomo Electric Carbide Inc.'s new PWS Shoulder Milling Cutter Series boasts the power to handle a variety of materials, including steels and cast irons.
The PWS Shoulder Mill is tangentially mounted for unprecedented cutting edge strength, according to the company. Its two-step insert array structure responds to deep cutting requirements, while optimized breakers provide excellent edge sharpness and cutting ability. A17mm insert allows for exceptional material removal. The serrated design of the insert, created with high-precision molding technology, provides stable milling (even in large overhang applications).
The PWS is available in diameters ranging from 80mm to 250mm, in both coarse and fine pitch diameters.
- cast irons
cast irons
Cast ferrous alloys containing carbon in excess of solubility in austenite that exists in the alloy at the eutectic temperature. Cast irons include gray cast iron, white cast iron, malleable cast iron and ductile, or nodular, cast iron. The word “cast” is often left out.
- milling cutter
milling cutter
- milling machine ( mill)
- pitch
pitch
