![QUAD 7 Carbide-Tipped Bandsaw Blades for Demanding Apps QUAD 7 Carbide-Tipped Bandsaw Blades](/sites/default/files/styles/product_image/public/product_images/SimondsSawQuad7.jpg?itok=H8AgxCUm)
Simonds Saw introduces QUAD 7 carbide-tipped bandsaw blades for demanding production cutting operations, such as steel service centers, foundries and aerospace sawing applications. QUAD 7 blades are suitable for alloy; high chrome alloy; Inconel and other nickel-based alloys; titanium block and plate; stainless steels; and mold, tool and bearing steels.
QUAD 7 Blades feature a positive rake angle, four-tooth pattern that produces seven distinct chips. This provides exceptionally high material penetration for faster cutting in production sawing alloy applications, according to the company.
“With today’s increased use of exotic alloys in production sawing, the need for more aggressive cutting solutions is pronounced. Our innovative QUAD 7 tooth pattern was developed to address this and customers have responded very positively to initial testing,” said Dale Petts, Simonds Saw’s global product manager.
Simonds QUAD 7 carbide-tipped blades are available in five widths: 3/4” x .050, 1-1/2” x .050, 2” x .062, 2-5/8” x .062 and 3-1/8” x .062 and are shipped in 150’ coils. Variable tooth pitch (TPI) options include 2.5-3.5, 2-3, 1.9-2.1, 1.4-1.8, 1.1-1.4, and .9-1.1 teeth per inch. Blades are furnished with plastic capping to protect teeth against damage in transit and handling.
- alloys
alloys
- bandsaw
bandsaw
Machine that utilizes an endless band, normally with serrated teeth, for cutoff or contour sawing. See saw, sawing machine.
- centers
centers
- pitch
pitch
- rake
rake
- sawing
sawing
- sawing machine ( saw)
