Millstar’s Quad Force Machining carbide cutting tools provide four cutting actions in one tool. The series uses advanced chipmaking technology that combines geometries for high-speed machining, trochoidal machining, plunge milling, and slide and slot milling, according to the company. The tools are suitable for cutting soft or hard tool and die steel, stainless steel and titanium. The multifunctional design eliminates the need for additional tools, decreases the number of tool changes and simplifies programming.
- plunge milling
plunge milling
Highly productive method of metal removal in which an axial machining operation is performed in a single tool sequence. The tool makes a series of overlapping, drill-like plunges to remove part of a cylindrical plug of material one after another. Because of the increased rigidity of a Z-axis move, the tool can cover a large cross-section of material.
