Greenleaf Introduces Line of Quick-Change Toolholders
Saegertown, PA: Greenleaf Corporation has announced the launch of its line of quick-change toolholders, or ISO- standard toolholders with quick-change shanks. The Greenleaf Quick-Change Toolholders conform to ISO 26623, utilize standard components, and are designed to maximize tool life in carbide and ceramic turning applications.
According to Bernie McConnell, Executive Vice President - Commercial at Greenleaf Corporation, “The Greenleaf Quick- Change Toolholders expand our tooling portfolio and open up a significant market opportunity.”
Features and benefits of the Greenleaf Quick-Change Toolholders include:
ISO 26623 shanks available in C6 and C8 sizes
Two high-pressure coolant nozzles precisely aimed at the cutting edge to aid in chip removal and improve tool life
All holders designed with additional axial and radial clearance to allow for use in both external and internal turning
applications
Holders for positive V-bottom inserts use replaceable nests, resulting in lower replacement costs if damage
occurs
Holders for negative inserts utilize same 10° side rake angles as our standard ceramic turning toolholders proven
to offer better tool life with Greenleaf ceramic inserts
Holders for negative inserts are designed to hold pinlock inserts using optional components
Greenleaf’s special design capabilities offer customers unique solutions to further increase productivity.
- clearance
clearance
- coolant
- rake
rake
- turning
