RA-6000CNC CNC Roundness/Cylindricity Measuring System
Mitutoyo announces the release of the RA-6000CNC, a custom-built CNC roundness/cylindricity measuring system with best-in-class accuracy. The RA-6000CNC is designed to measure large-size, heavy, cylindrical workpieces generally associated with automotive, energy, marine and aviation industries.
December 9, 2016
The main features of the RA-6000CNC include:
• Designed for large size, heavy workpieces requiring roundness/cylindricity evaluations.
• Highest rotational accuracy (0.05+6H/10000) µm among large-size roundness measuring systems.
• Maximum table loading capacity of 772 lbs. (350kg).
• Maximum probing diameter of 34.6" (880mm).
• Maximum probing height of 41.3" (1050mm).
• Measuring range, such as diameter and height, is customizable depending on customer requirements.
