RD2500 Large-Format Dispensing System
Dispense Works Inc. offers several large-format dispensing systems. The RD2500—manufactured in the U.S.—is a highly flexible large-format dispensing table.
June 20, 2019
This robot combines a smart work bench to a built in precision overhead servo XYZ gantry system.
Mechanisms are neatly tucked in and do not add to the width of the bench—this provides easy access from front, sides and top requiring less operator "reach" to the center of the table.
Another unique design feature is the 25 full length slots in the T-Slot table base plate providing multiple fixturing possibilities for most applications. Under this table surface, the actual machine base is fabricated from steel tubing, and then is ground to a specified flatness.
This modular design provides the ideal foundation for mounting virtually any type of top surface, including T-slot table, vacuum table, panel conveyor and custom plates.
Standard machine can travel at over 32 inches per second and is available in the following travels:
100" x 50" (2,500mm x 1,250mm) and 50" x 50" (1,250mm x 1,250mm)
The company offers limitless customizing capabilities for other sizes.
