reCool RCR/ERM Retrofittable Coolant-Through System
REGO-FIX has introduced a new addition to its line of reCool retrofittable coolant-through systems. The reCool RCR/ERM not only provides all the benefits of reCool technology to Swiss-style machines, but also allows the use of emulsion or pure oil coolants.
July 20, 2016
Like its companion system, the new reCool RCR/ERM cost-effectively converts existing flood-cooled driven tools with ERM mini threads to through-tool-coolant capable in as little as 2 minutes. The system gets coolant to the cutting edge much more effectively than do spray piping or nozzles, and thus easily removes heat from the cutting zone and contributes to better surface finishes, longer tool life, improved chip control and increased productivity, according to the company.
The reCool Mini accommodates standard speeds up to 12,000 rpm and coolant pressures up to 1,450 psi (100 bar) and 2,150 psi (150 bar) is optional.
