REV Motorized Slotter
The REV motorized slotter is designed to solve, in the most efficient way, the problem of having to perform certain processing operations on a CNC lathe, from a simple keyway to internal or external toothed profiles.
February 28, 2020
The REV motorized slotter is designed to obtain maximum rigidity. This feature allows the insert to be used for a long time and the processed surface to have an excellent degree of finish.
There are remarkable advantages in using this slotter: in addition to its extremely fast processing speed, the piece does not need to be moved on other machines, thus avoiding further tool set-ups.
The REV motorised slotter has several adjustments, which are useful for achieving correct processing, and can perform internal or external processing.
The REV motorised slotter is protected by patent.
Advantages:
• Y- and Z-axis correction (patent protected aspect);
• Extreme rigidity, a characteristic that ensures an excellent degree of finish and, at the same time, a long life of the cutting edge of the insert; and
• Time saving, allowing to carry out the work in extremely fast times and avoiding, at the same time, the movement of the piece and the use of additional machine tools.
