Rex Cut offers full line of cotton fiber abrasive products
A full line of cotton fiber abrasive products for grinding, deburring, polishing, and finishing stainless steel, aluminum, and exotics is available from Rex Cut Products Inc.
Rex-Cut Cotton Fiber Abrasive Products feature multiple layers of non-woven cotton fabric impregnated with aluminum oxide or silicon carbide abrasives which are compressed with varying bond hardness for use on stainless steel, aluminum, and exotics. Continually exposing fresh abrasives while working, they run cool, provide smooth, chatter-free performance, and are capable of grinding, deburring, and finishing in one operation.
Unlike most bonded or coated abrasives, Rex-Cut Cotton Fiber Abrasive Products do not load up when working on softer metals or alloys and do not back transfer or smear on harder alloys. They include Type 1 straight-sided abrasive wheels, Type 27 depressed center wheels, Cut-N-Finish flexible discs, mounted wheels and points, quick change discs and sticks.
  • abrasive
    abrasive
  • alloys
    alloys
  • aluminum oxide
    aluminum oxide
    Aluminum oxide, also known as corundum, is used in grinding wheels. The chemical formula is Al2O3. Aluminum oxide is the base for ceramics, which are used in cutting tools for high-speed machining with light chip removal. Aluminum oxide is widely used as coating material applied to carbide substrates by chemical vapor deposition. Coated carbide inserts with Al2O3 layers withstand high cutting speeds, as well as abrasive and crater wear.
  • grinding
  • hardness
    hardness
  • polishing
    polishing
