Utilizing newly engineered ceramic grain, high-performance Rigid Kut quick-change discs from Superior Abrasives are designed for demanding burrs, heavy stock removal, and weld grinding.
The top size helps to reduce heat and the self-sharpening grain excels in high pressure applications. The robust triple-ply backing ensures a durable edge designed to reportedly tackle any abusive application.
- backing
backing
1. Flexible portion of a bandsaw blade. 2. Support material behind the cutting edge of a tool. 3. Base material for coated abrasives.
- grinding
