Rotary and Indexing Tables
Zagar Workholding Group has added a complete line of rotary and indexing tables to its product offering.
Zagar Workholding Group has added a complete line of rotary and indexing tables to its product offering. Sold under the Zagar brand, the tables are available in various diameters and with right hand or back-mounted AC or DC motors. Standard table diameters range from 4.72 to 12.6 inches (120mm — 320mm). Special large size tables are available up to 117 inches.
All Zagar tables feature the following:
Auto home positioning and pneumatic brake systems
Precision bronze/nickel worm wheel and case hardened steel worm gear to insure long term indexing accuracy (specifications conform to the Japan Gear Association)
Dual pitch worm shaft that allows easy backlash adjustment
One piece faceplate and spindle design for maximum rigidity
Gear ratio of 90:1 provides high speed feed rate Available back mount motor design to accommodate minimum mounting space in small drilling and tapping CNC machining centers
Zagar tables are compatible with various models of servo motors and can be integrated with most 4th and 5th axis CNC controls. Zagar can also provide an American-made indexing controller that functions with any CNC or manual machine tool. The controller uses industry standard G-code programming and can be actuated via an RS-232 control signal.
