RS013N Medium Payload Robot
The robot's design includes a new arm structure, drive system and lighter main unit, which enables high speeds and a large working area. Its 1,460 mm reach is the largest in its class, allowing for installation flexibility and use in a wider variety of applications. The RS013N robot also leads its class in speed, resulting in reduced cycle times and increased productivity.
Kawasaki Robotics' dedication to continuous improvement is evident in their technically advanced general purpose robot line: the R series. With a history dating back to the mid-1980s, Kawasaki has continued to refine their general purpose robot arms over time, routinely producing robots with wider working ranges, faster cycle times, longer reach, and increased torque. The release of the RS007N/L models in 2017 marked the beginning of a new generation of Kawasaki R series and the latest model, the RS013N, is no exception. By offering a 13 kg payload capacity, a wide working range, small footprint and IP67-classified design, the NEW RS013N sets the industry benchmark for small-to-medium payload robots.
Industry Leading Speed & Flexibility
The new robot's design includes a new arm structure, drive system and lighter main unit, which enables high speeds and a large working area. Its 1,460 mm reach is the largest in its class, allowing for installation flexibility and use in a wider variety of applications. The RS013N robot also leads its class in speed, resulting in reduced cycle times and increased productivity.
Enhanced Versatility
In addition to its expanded work area, the robot's wiring and installation options contribute to its overall flexibility. The robot's internal Ethernet wiring enables easy connection to a vision system or other peripheral devices, and its floor, ceiling and wall mount options provide installation flexibility for any layout. The dust-tight RS013N offers a full-body IP67 rating, fully covered motors and waterproof electrical connections allow the robot to Kawasaki's next generation R series robots (RS007N/L and RS013N) also have reduced interference zones around the robot base, which allows the user to maximize their floor space and working area.
Built for Longevity
Kawasaki's new R series robots are designed with ease of use and longevity in mind. The motor has been moved and covered to protect it from harsh environments and workplace wear, and the new motor location on the base allows for enhanced protection and easier serviceability.
