RT 100 S Drill
RT 100 S Drill
The RT 100 S drill from Guhring was especially developed for the complex machining of steel materials. It reportedly scores points thanks to high cutting values and consistently good hole quality. An especially stable and accurate cutting edge is produced thanks to the special micro-geometry.
February 6, 2017
The extremely smooth surface finish of the RT 100 S web thinning and flute profile reduces the friction between drill and chip. The machining temperature is reduced and chip evacuation improved. Cutting forces are reduced. These tool features result in maximum hole quality and tool life, according to the company,
Application include:
structural and free-cutting steels
alloyed and unalloyed heat-treatable steels
alloyed and unalloyed case hardened steels
tool steels and high speed steels
