RubyLaser FLC Fiber Laser Cutting System
September 26, 2017
The design team at Automation Alternatives knew that in order for a system to be truly cost-effective, it had to combine highly efficient technology with user-friendly operation. According to the company, the RubyLaser FLC does just that and more. Sporting a  compact footprint, the RubyLaser FLC series boasts unsurpassed efficiency using a third of the power, as well as less gas than comparable CO2 systems.  Additional cost savings are realized from lower service costs---service intervals are reportedly half as frequent and half the cost.
The system was designed from the ground up with the operator in mind. To that end, a number of design considerations were incorporated that enable operators to work both efficiently and comfortably. Cuts are placed using the guide laser and targets. With special clamps acting as hard stops as they hold the work material in place, the usable area on each sheet is maximized and, with minimal stops per sheet, allows an operator to run an entire sheet without stops.
The RubyLaser FLC includes user-friendly software to simplify machine operation and an automated, feather-touch pallet system eases both loading and unloading. In addition, hand-held controls are provided to free the operator from the console.
Machine up-time is another critical consideration. With the cost of replacing a damaged cutting head running between $10,000 and $30,000 and lost production as the result of job stops creating a hit to companies’ bottom lines, the engineers at Automation Alternatives knew that these were problems that needed solutions.
A range of features that virtually eliminate head crashes and that minimize job stops have been incorporated into the RubyLaser FLC design. Automation Alternative engineers have included a cutting-head crash-plate that serves to protect both the head and the work material. In addition, a smaller-diameter nozzle tip requires less clearance between parts and a precision gap sensor is able to consistently follow the surface of the work material. These and other innovative design features virtually eliminate the possibility of head crashes, the company reports. Also, although a seemingly obvious design feature, an audible alarm will sound in the unlikely event of a job stop.
Power levels are available from 150W to 4kW with enhanced energy efficiency and a laser life upwards of 100,000 hours. Systems feature tolerances of +/-0.001" and fast cycle times without sacrificing edge quality. Working platforms range from 2 x 2, 4 x 4 and 4 x 8 feet. In addition, vision systems are available that have been proven in over 90 installations and have been specifically configured by Automation Alternatives for its cutting and welding systems.
  • clearance
    clearance
PRODUCTS
11/20/2024
10/23/2024
10/23/2024
