RushCut Cut-Off Machine
RushCut Cut-Off Machine Is Fully Enclosed Semi-Automatic, Designed for Quick, Easy Cutting
Rush Machinery will showcase the RushCut Cut-Off Machine at the 2024 International
Manufacturing Technology Show in Chicago, Illinois from September 9-14 .
Based on the Easy-Cut, the new and improved RushCut is a fully enclosed semi-automatic cut- off machine, designed for quick and easy cutting of carbide rod, high speed steel, and tool ends with diameters between 1/8′′ (3.175 mm) to 1-1/4′′ (31.75 mm). PLC controlled, the RushCut has air actuated work piece clamping and hydraulic feed cutting stroke with a neutral button for manual positioning/feeding. Proudly built in the USA.
  • feed
