Rustlick is excited to announce the release of a new premium, bioresistant water-soluble oil cutting fluid. ULTRACUT Pro delivers reliable performance in a wide range of machining and grinding applications.
R&D Chemist Steve Badger II, explains, "ULTRACUT Pro uses the very latest lubrication and antimicrobial technologies for a coolant that is highperformance, long-lasting, and extremely hard water stable."
The dependable performance of ULTRACUT Pro makes it a first choice for manufacturers working for industries as diverse as aerospace, automotive, agriculture, energy, industrial components, job shops, plastics, and transportation. ULTRACUT Pro delivers proven resistance to microbials, like bacteria and fungus, and is shown to last longer than competitive coolants without the need for costly additives.
In independent lab studies, ULTRACUT Pro lasted longer and outperformed top competitors in bacterial and fungal resistance. This hard water stable formula is effective in a wide range of light, moderate & heavy-duty applications, including machining, cutting, grinding, milling, broaching, threading and turning.
"ULTRACUT Pro's tight emulsion guarantees consistent, dependable lubrication and cooling for great tool life and surface finish with less carryoff," states Badger.
ULTRACUT Pro contains no boron, phenol, nitrites, triazines, sulfur, copper or SARA 313 reportable chemistry and is easy to recycle or dispose of with conventional techniques and equipment. Rustlick ULTRACUT Pro is available in 5 or 55 gallon containers and is recommended for ferrous and nonferrous metals, aluminum, brass, bronze and copper. The nonchlorinated version, ULTRACUT Pro CF, is recommended for all metals, including titanium and high nickel alloys.
- alloys
alloys
- broaching
broaching
Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
- coolant
- cutting fluid
cutting fluid
Liquid used to improve workpiece machinability, enhance tool life, flush out chips and machining debris, and cool the workpiece and tool. Three basic types are: straight oils; soluble oils, which emulsify in water; and synthetic fluids, which are water-based chemical solutions having no oil. See coolant; semisynthetic cutting fluid; soluble-oil cutting fluid; synthetic cutting fluid.
- emulsion
emulsion
Suspension of one liquid in another, such as oil in water.
- grinding
- threading
threading
- turning
