SafeSite Glass Reinforced Polyester LED Fitting
Dialight launched its new SafeSite Glass Reinforced Polyester (GRP) linear form factor for the APAC and EMEA markets. This LED fitting includes IECEx/ATEX Zone 2, 21 and 22 certification for hazardous applications, including upstream and downstream oil and gas, petrochemical, mining and heavy manufacturing applications.
Easy to install, the fixture is available in 764 mm and 1,244 mm lengths with a lumen output range of 2,785 to 5,750 lumens. Together with Dialight's 10-year warranty, the GRP linear provides a reliable, low maintenance solution with triple the lifespan of fluorescents, even in the world's most demanding conditions.
"Dialight's new GRP linear represents another key advancement in engineering, safety and longevity for harsh and hazardous industrial environments," said Fariyal Khanbabi, Dialight Group chief executive. "We are justifiably proud to be able to bring our expertise to the market with a superior solution that is optimised for long life in challenging environments and offers one of the widest ambient temperature ranges on the market."
Designed from the ground up and featuring Dialight's exclusive in-house designed power supply and thermal management system, the SafeSite GRP LED Linear can withstand ambient temperatures between -40° C up to +65° C. The durable, corrosion resistant GRP housing material has excellent structural, thermal and chemical resistance properties.
The SafeSite GRP LED linear is impact resistant and rated IK08. It is also IP66/67 rated making it impervious to water and dust.
This new offering from Dialight also provides optional battery backup with field-selectable durations of 60, 90 and 180 minutes to allow end users to easily conform with local regulations for minimum EM durations for egress lighting purposes.
Additional safety features include four stainless steel retention tabs, an optional wire guard accessory, a wildlife, eco-friendly amber solution and a green shower safe and eye wash station option. Unlike conventional fluorescents, this product does not contain harmful toxins such as mercury.
The new SafeSite GRP Linear range is controls-enabled, offering DALI 1.0 / 2.0 as standard across the range and is dimmable from 100% down to 5% to provide greater efficiency and energy savings.
Wireless connectivity future proofs your lighting installation, enabling automation and control of your lighting system immediately or at a later date.
