SafeSite LED Fixture
Dialight unveiled an energy efficient Class 1, Division 1 LED High Bay at 110 lumens per Watt (LPW).
Dialight unveiled an energy efficient Class 1, Division 1 LED High Bay at 110 lumens per Watt (LPW). The new SafeSite LED High Bay delivers up to 23,500 fixture lumens, making it reportedly ideal for a number of applications in oil, gas and petrochemical environments.
Featuring Dialight's in-house designed power supply, next generation LED technology and advanced optical design, the new SafeSite LED fixture marks a major step forward in the future of energy efficiency for hazardous environments. The new fixture is typically able to reduce energy consumption by more than 50 percent. Where conventional HID system wattage averages 460W, Dialight's new Class 1 Div. 1 High Bay draws just 212W. In addition to maintenance savings, this improves facilities' safety conditions by minimizing the need for personnel to enter hazardous locations.
At 30 lbs., the 100-277VAC SafeSite LED High Bay is rated to operate in ambient temperatures ranging from -40 degrees C to +65 degrees C and boasts a T5 temperature rating at 50 degrees C. The highly efficient SafeSite High Bay ships standard with 6kV surge protection and is IP66/NEMA4X certified. The SafeSite High Bay is also available with custom in-house designed optics including medium and wide distribution types, with numerous flood light distribution options coming soon.
