Tapeswitch Corp. offers a compact, lightweight, easy to program safety laser scanner for collision prevention, presence detection, and perimeter protection.
This compact, lightweight laser scanner offers a wide area detection zone at 190 degrees and is easily set to a maximum protection range of 2 meters and maximum warning range of 10 meters depending on the application. Status indicators, located on the front of the scanner, depict a seven segment display and currently selected area and error number in real time. Get the most out of a coverage area possibilities with mounting bracket options for both vertical and horizontal mounting. The scanner is compact and miniature with dimensions only 3 13/16" H x 3 9/16" W x 3 15/16" L.
The unit is IP65 rated for environmental conditions. The unit has low power consumption. The laser scanner offers a single protection zone with 16 pattern combination and two warning zones (non-safety) for complex-shaped environments.
