Saw Blades and Side Chip Clearance Saws
Controx-Neuhauser presents a full line of standard saw blades and side chip clearance saws suitable for a wide range of precision cutting applications. Available in U.S. Imperial dimensions with diameters from 1" to 8" and metric dimensions from 20mm to 250mm, with fine, medium and coarse tooth pitch to suit application requirements.
In addition to these standard saw blades and side milling cutters, Controx-Neuhauser also stocks replacement blades for Hydromat, George Fischer, Rohbi, Bimax, Presstal Eisele, different Screw-, Swiss-type- and other machines. Controx standard saw blades are manufactured from HSS, cobalt steel (HSSCo) or solid carbide and are available with or without PVD or CVD coating to enhance performance and service life.
An in-house heat treatment facility ensures optimum quality saw blades and fast delivery. They are suitable for a wide range of applications including, gold and silver jewelry, fastener production, resistors, electronics, thin or thick-walled pipes and profiles, extrusions, abrasive and high-tensile materials.
