Controx-Neuhauser presents precision saw blades designed specifically for use with Hydromat machines. Available in 166 and 250 mm diameters, these cobalt steel (HSS-Co) saw blades feature an axial runout of 0.1 mm/0.004” to assure a straight cut and minimize the breakage rate.
To accommodate the range of material sizes and types processed, Controx-Neuhauser stocks untoothed saw blade blanks which are then customized for particular applications. The number of teeth and the toothform ensure minimal burr issues and maximum service life. Fine-, medium- and coarse-pitch toothing available includes angular (A), angular with alternating chamfers (Aw), rounded (B), rounded with alternating chamfers (Bw), or Triplechip toothing (C) styles.
PVD and CVD coatings are available for enhanced performance and service life. Controx precision saw blades are ideal for diverse applications including, gold and silver jewelry, fastener production, resistors, electronics, thin or thick-walled pipes and profiles, extrusions, abrasive and high-tensile materials.
In addition to saw blades for Hydromat machines, Controx-Neuhauser also stocks replacement blades for George Fischer, Rohbi, Bimax, Presstal Eisele, different Screw- and Swiss-type and other machines.
- abrasive
abrasive
- burr
burr
- chemical vapor deposition ( CVD)
- sawing machine ( saw)
