SC2818 Stepper Motor
With the SC2818, Nanotec presents a stepper motor with a flange size of 28 mm and a torque of up to 0.22 Nm. The SC2818 thereby boasts in excess of 30 percent more torque than conventional motors of the same size. The step angle of the 2-phase hybrid stepper motor is 1.8°.
January 25, 2018
Like the other SC series motors from Nanotec, the SC2818 has an integrated connector, thus making it easy to adapt cables for customized applications. A connection cable is included in the scope of delivery. The SC2818 motors are available in three lengths, each with one or two shafts. The version with the B-shaft is optionally offered with an NOE1 encoder with up to 2,000 increments/revolution.
Due to its high torque and small size, the SC2818 motor series is ideally suited for use in laboratory automation or in service robotics.
