Seco Stabilizer End Mills
The Seco Stabilizer end mills enhance chip evacuation, improving process security for high-performance operations.
March 31, 2025
Seco's new Stabilizer™ end mills feature flute geometries designed for low material removal costs in 2D applications such as slot, pocket, and side milling. The tools are equipped with a SIRON-A wear-resistant coating that extends tool life and increases flexibility.
The 4-flute end mills incorporate a continuously varying asymmetrical flute geometry, while the 5-flute variants feature different helix and rake angles on each flute. These designs provide stability, reduce harmonics and chatter, and enable high-speed machining, resulting in cost-efficient material removal.
The Stabilizer end mills also enhance chip evacuation, improving process security for high-performance operations. The tools are ideal for steels, cast iron, stainless steels, titanium, and superalloys, offering extended tool life and reduced tooling costs.
The latest generation of Stabilizer end mills consolidates Seco's cutting tools into a unified global brand. Customers upgrading their existing tooling will now have access to a broader range of solutions.
  • stainless steels
  • superalloys
