Self-Tuning Mass Damper Toolholder
MAQ offers the Self-Tuning Mass Damper (STMD). This toolholder features a tungsten mass inside the tool. It is available in more than a dozen length-diameter combinations. By using the STMD, parts manufacturers, machine tool builders and cutting tool manufacturers can reduce cycle time and cost of ownership by 30 percent, decrease tooling costs by 5-10 percent, cut energy consumption by 2-3 percent and curtail scrap output by 1-2 percent.
September 12, 2018
"The STMD is totally plug-and-play, and maintenance free," says Dr. Qilin Fu, MAQ's CEO and a co-founder of the company. "The STMD technology enables automatic tuning of the mass dampers, without using complex mechatronic systems. It also minimizes the need for tooling changes and is a cost-effective alternative to complex de-vibe tools that require manual adjustment. Given the high volume of machining operations, even the smallest percentage reductions can result in substantial savings. "
The tungsten mass is supported by special polymer discs that have frequency-dependent stiffness. As cutting forces are applied to the tool, vibration occurs on a frequency band. To counteract such movement, the MAQ STMD self-adjusts to that frequency to maximize the mass damping effect.
According to tests conducted at a leading machine tool builder in March 2018, the MAQ STMD showed significantly less displacement than other toolholders and demonstrated superior versatility with respect to speeds, feeds, depth of cut and L/D ratio.
MAQ STMD toolholders improve feeds and speeds, decrease adjustment time and promote superior surface finishes that don't require secondary operations. With STMD, it becomes unnecessary to slow down, reduce depth of cut or otherwise lengthen cycle time.
  • depth of cut
  • toolholder
