SHA-4000 Automated Power Stroke Honing System
The SHA-4000 from Sunnen Products Co. is a premium system for high-volume processing of gears, turbocharger bushings, cartridge valve components and pistol barrels, among others. With the popular SH-4000 as a base, the SHA-4000 integrates Swiss automation to create an off-the-shelf, robust, high-production system that requires minimal operator attention.
The SHA-4000 from Sunnen Products Co. is a premium system for high-volume processing of gears, turbocharger bushings, cartridge valve components and pistol barrels, among others. With the popular SH-4000 as a base, the SHA-4000 integrates Swiss automation to create an off-the-shelf, robust, high-production system that requires minimal operator attention. The automation package consists of proven part handling technology combined with heavy-duty production part filtering, and the system is engineered to optimize productivity with a focus on reliability and maintainability.
Diameter Range (ID):
- 1,5 mm to 101.6 mm (.060 in. to 4.0 in.) diameter
Stroke Length:
- 6 to 392 mm (.24 -15.43 in)
FEATURES & BENEFITS
- Patent pending digital-servo, linear hybrid tool feed and cutting pressure control.
- 20 mm (.79 in) of additional feed travel for increased diameter range for MMT tools.
- All electric foot pedal for setup and truing mandrels.
- Coolant tank is 70 percent larger than earlier models - 208 L (55 gallon)
- Generous ergonomic work area.
- Intuitive touchscreen is easy-to-use with a large 225 mm (9 in) display.
