Sheet Fanners
Sheet Fanners
Eriez Sheet Fanners feature a powerful magnetic circuit to easily fan and separate semi-sticky, oily, bent and heavy gauge sheet steel.
January 1, 2015
Eriez Sheet Fanners feature a powerful magnetic circuit to easily fan and separate semi-sticky, oily, bent and heavy gauge sheet steel. They bring new efficiency to slow, costly, difficult sheet feeding to presses, brakes and shears.
Eriez Sheet Fanners increase production and reduce labor hours. With these units in operation, there is no prying required and doubles are eliminated. They also protect product quality because they will not mar painted or polished surfaces.
Eriez Sheet Fanners are designed with hand cutouts, allowing them to be easily transported from one point to another. The sturdy base enables fast mounting to any flat surface.
All units are built with a stainless steel "U" shaped frame with stainless anti-friction strips and back cover. The magnetic circuit is completely enclosed. It is rugged, tamper-proof and able to withstand severe usage.
With three available strengths in four functional heights, Eriez range of Sheet Fanners provide complete coverage for applications up to 18" (3mm) thick steel sheets stacked up to 14" (355mm) high. Select models are offered for next-day shipping through the EriezXpress Program.
