Shefcut Nonadjustable Reamers
Using the proven and time-tested Shefcut reamer design, Cogsdill now adds a new twist. Shefcut precision reamers and fine boring tools have always been designed to produce accurately sized, extremely straight and round bores, with fine surface finishes, according to the company.
May 13, 2016
While easy to set, some customers have requested the benefits of the standard design but with easy or no
adjustment. Shefcut nonadjustable reamers are designed for a specific bore diameter with no setting of the cutting blade required. The design utilizes a replaceable precision ground carbide cutting blade with one cutting edge. Shefcut nonadjustable reamers are for applications where the bore tolerance is +/-.0005" (0.0127mm) or greater.
