SHOCKWAVE RED HELIX Titanium Drill Bits
June 20, 2020
SHOCKWAVE Red Helix Titanium Drill Bits. Engineered for Extreme Durability
Milwaukee Tool continues to enhance their line of twist-drilling accessories with the next generation of their SHOCKWAVE™* Red Helix™ Titanium Drill Bits. Engineered for extreme durability and longer life in wood, plastic, and metal applications, these new bits provide up to 5X life versus black oxide drill bits.
New to this next generation of Red Helix™ Drill Bits are two features: a Quad Edge™ Tip and Enhanced Tapered Web™. The Quad Edge™ Tip delivers a longer life with a precision start and four cutting edges to stay sharper longer. The drill bits’ Enhanced Tapered Web™ acts as an internal backbone and strengthens the bit to reduce premature breakage; a common user frustration.
Like the Red Helix™ Cobalt Drill Bits that launched last year, the next generation of Red Helix™ Titanium Drill Bits are designed with a Variable Helix™ that includes an aggressive 35° helical angle that varies along the flute, ending at 15° limiting heat build-up for faster material removal.
The next generation of Milwaukee’s SHOCKWAVE™ Red Helix™ Titanium Drill Bits are ideal for use with both drills and impact drivers and will be available in sizes ranging from 1/16” to ½”, as well as in sets. The drill bits will be available for purchase at select distributors in July 2020.
SHOCKWAVE™ Accessories delivered the first line of power tool accessories specifically designed for use with impact drivers. As tool usage and technological advancements within impact drivers has rapidly increased, SHOCKWAVE™ has continued to innovate and provide tradesman with the best performing impact accessories available.
Quick Reference
Red Helix™ Titanium 1/16”, 5/32”, 3/32”, 7/64”, 1/8” 9/64”, 5/32”, 11/64”, 3/16”, 13/64”, 7/32”, 15/64”,1/4”, 17/64”, 9/32”, 19/64”, 5/16”, 21/64”, 11/32”, 23/64”, 3/8”, 25/64” 13/64”, 27/64”, 7/16”, 29/64”, 15/32”, 31/64”, ½”
SHOCKWAVE™ Red Helix™ Titanium Drill Bit Sets
15 PC SHOCKWAVE™ Red Helix™ Titanium Drill Bit Set       48-89-4630
23 PC SHOCKWAVE™ Red Helix™ Titanium Drill Bit Set       48-89-4631
29 PC SHOCKWAVE™ Red Helix™ Titanium Drill Bit Set       48-89-4632
10 PC SHOCKWAVE™ Red Helix™ Titanium Drill Bit Set       48-89-4633
4 PC SHOCKWAVE™ Red Helix™ Titanium Drill Bit Set         48-89-4644
  • black oxide
    black oxide
    Black finish on a metal produced by immersing it in hot oxidizing salts or salt solutions.
Sponsored Content
