Kyocera Precision Tools introduces the new SIGC small internal grooving tool. The SIGC toolholder has a newly developed clamping system providing a firm insert hold made for the most efficient high-precision machining.
Double coolant holes provide additional wear resistance while the optimized flute shape effortlessly removes chips from the cutting edge. With a minimum bore diameter of 8mm, the SIGC is highly suitable for small internal grooving applications.
- coolant
- grooving
grooving
- toolholder
toolholder
- wear resistance
wear resistance
