SintoGrind HSS Grinding Oil
SintoGrind HSS from oelheld U.S. was especially developed for profile and flute grinding of steel alloys and in particular for high-speed steel and medical steel.
It is based on synthetic Polyalphaolefins free of chlorine or heavy metal compounds. All additives are synthetic and have excellent high pressure (EP) and superb lubrication properties. Most important the product is physiologically absolutely safe. Oil misting and evaporating tendency is very low and it has an excellent viscosity-temperature relationship.
Due to its 100 percent synthetic formula, SintoGrind HSS cools, lubricates and cleans better than any mineral oil based grinding oil and has grinding wheels remain clean and unclogged. SintoGrind HSS has an extremely low evaporation and misting rate and sheds air very quickly and does not foam. Tangential forces and work piece temperatures will be greatly reduced with the use of SintoGrind HSS.
