SoftFinish Comfort Grip Hand Tools
Wiha Tools offers a broad range of problem-solving, professional-quality tools.
September 1, 2015
Wiha Tools offers a broad range of problem-solving, professional-quality tools. With more than 5,000 hand tools, the company says its goal is to manufacture only hand tools that allow users to work more efficiently, functionally and ergonomically.
The SoftFinish "Comfort Grip" hand tools are easy on the joints and wear-resistant, according to the company. One of highlights is the SoftFinish Pop-Up bit holders. With an option to store either insert bits in the handle or insulated SlimLine bits in the SoftFinish 1,000V insulated handle make this bit holder a space-saving hand tool. The Pop-Up versions feature 12mm insert bits or 70mm insulated SlimLine bits. Energy saving and comfortable screw fastening is possible thanks to an ergonomic handle design.
Wiha also offers BiCut SuperCut in three SoftFinish styles: SoftGrip, two-component industrial SoftGrip and 1,000V insulated industrial Cushion Grip. BiCut SuperCuts completes the job of two pairs of pliers, with up to 50 percent less hand strength required for cutting. Users can double the power at the press of a button. The tools are suitable for cutting soft to extremely hard materials, including nails, scres, bolts, wire cables, spring wires and chains.
