Spindle drawbar pull-force tester
The ForceMaster spindle drawbar pull-force tester from Rego-Fix tests proper machine tool spindle drawbar pull-force, which is an important aspect of overall spindle preventive maintenance and performance. With more than a dozen available adapters, ForceMaster works on virtually any machine tool spindle interface.
July 30, 2025
The ForceMaster spindle drawbar pull-force tester from Rego-Fix tests proper machine tool spindle drawbar pull-force, which is an important aspect of overall spindle preventive maintenance and performance. With more than a dozen available adapters, ForceMaster works on virtually any machine tool spindle interface, including HSK, SK, BT, and CAT, the company says.
ForceMaster features an IP67 certified dust and waterproof body ergonomically designed for a sure grip and comes with a rugged protective case tough enough for the shop floor. In use, operators simply thread on the appropriate adapter, insert the tool into the machine spindle and push a switch.
The company says the ForceMaster easily integrates into digital production environments and is fully accessible via a mobile phone app available for Apple and Android devices. Shops can then mirror the tool's dashboard to perform measurements remotely, and all information is downloadable for analysis and tracking.
