Spindle gripper for unattended machining
Jergens adds MT-S to its range of workholding products for automated and unattended applications for greater machine utilization.
Jergens adds MT-S to its range of workholding products for automated and unattended applications for greater machine utilization. The MT-S spindle gripper allows continued machine cycles by picking and placing finished components in a temporary part loading tray located on the machine table.
Functioning as a first-level automation solution – without a robot – MT-S is stored in the tool magazine like any tool and engaged at the end of each cycle. Depending on the part size and configuration, many pieces can be machined and stored with little or no operator intervention. Pre-machined parts are loaded, machined, and placed (unloaded) by MT-S, allowing a continuous cycle until the part loading tray is full. An easy-to-adjust gripping force plus counterbalance function ensures that all components are optimally protected.
MT-S comes with several gripper styles and easy-to-change inserts that match part geometrical needs. The unit's power source can be either pneumatic (air through the spindle) or hydraulic (coolant supply). The spindle gripper reduces set-up times for small to medium-sized batches of workpieces up to 17.6 lbs. (8 kg).
The new gripper requires no additional floorspace, has a lower initial investment compared to robotics, and is easy to train without extensive programing. MT-S is one of several automation solutions that also includes a machine washdown tool, Zero Point System (ZPS), and a range of pneumatic and hydraulic devices.
