Spiral-Flute Pipe Taps
Allen Benjamin Inc. has introduced a line of high performance, application-specific HSSE spiral-flute pipe taps.
September 13, 2013
The taps are specifically designed and engineered to handle the most demanding pipe tapping applications for NPT and NPTF thread forms. Made with HSSE premium high speed steel, these Allen Benjamin pipe taps increase threading efficiencies, productivity and throughput in a broad range of materials.
The taps are manufactured to Table 311 standard pipe tap dimensions for straight and taper styles, and are designed with standard projection length. Steam oxide coating is standard and alternate coatings are available depending on the specific application.
