Squareworx Multifunctional Milling System
Squareworx is a multifunctional milling system from POKOLM for machining with both 90° and 45° approach angles and only a single insert. One insert is thus enough to perform square shoulder, slotting, face and chamfering milling operations.
Squareworxis a multifunctional milling system from POKOLM for machining with both 90° and 45° approach angles and only a single insert. One insert is thus enough to perform square shoulder, slotting, face and chamfering milling operations.
Each insert has four useable cutting edges with a corner radius of 0.8 mm. Cutting materials in five different grades cover the machining of all standard materials, ranging from roughing to finishing.
All of the available shell-type, threaded shank and endmills possess the maximum possible number of teeth. In combination with the mandatory internal coolant supply, this feature allows high feed rates. The square shoulder and slotting cutters are available from stock in diameters between 25 and 66 mm. With the 16 to 63 mm-dia. chamfering milling cutters, both forward and reverse chamfering operations are possible thanks to their special geometry.
Ease of cutting is always guaranteed, even with machines which feature less sophisticated geometry. Furthermore, the costs per cutting edge are extremely low thanks to the four-way use of each individual insert, in combination with high removal rates, according to the company.
