Stainless Steel Island Canopy Hoods
The canopy fume hood's smooth surfaces provide superior chemical, corrosion, and heat resistance. Optional side panels prevent cross drafts and further improve airflow while providing a way to contain chemical spills. Stainless steel canopy hoods are available in custom sizes including 168" wide X 60" deep, and are available with optional baffles.
August 2, 2023
Stainless Steel Island Canopy Hoods are designed to collect and exhaust corrosive vapors, soldiering operations, heat, steam and odors when mounted over areas with water baths, hot plates or portable equipment.
Manufactured of Stainless Steel, Island canopy hoods are lightweight and can be suspended from the ceiling over island locations using steel pipes. The canopy fume hood's smooth surfaces provide superior chemical, corrosion, and heat resistance. Optional side panels prevent cross drafts and further improve airflow while providing a way to contain chemical spills. Stainless steel canopy hoods are available in custom sizes including 168" wide X 60" deep, and are available with optional baffles.
