Studer S121 Radius Internal Cylindrical Grinding Machine
The Studer S121 radius internal cylindrical grinding machine from United Grinding North America Inc. has a swing diameter of 250mm (9.84") and can grind a maximum part length, including the clamping device, of 300mm (11.81"). The workpiece weight capacity, including the clamping device, is 100 kg (220.5 lbs.).
April 18, 2016
The Studer S121 radius internal cylindrical grinding machine from United Grinding North America Inc. has a swing diameter of 250mm (9.84") and can grind a maximum part length, including the clamping device, of 300mm (11.81"). The workpiece weight capacity, including the clamping device, is 100 kg (220.5 lbs.). The grinder can process extra-hard materials, such as industrial ceramic, sapphire and tungsten carbide, and is suitable for producing complex workpieces with tapers from 20° to 90° in a single clamping.
  • cylindrical grinding
  • grinding machine
