Phillips Precision’s Products Divi. announces its new Sturdy Lever clamp as part of the Inspection Arsenal LEAN, Quick-Swap inspection fixture system. Not only does Phillips Precision offer the only quick-swap standard fixture systems, but the company's provides quick, creative fixture design and quick shipping of orders. Inspection Arsenal tooling will help optimize an inspection process and uncover hidden profits.
The new heavy-duty Sturdy Lever cantilevered clamp is suitable for added force and for larger parts. Lever tightens with a thumb screw rather than downward force which makes this clamp less likely to mar the part. The clamp generates up to 30-lbs of force and can be adjusted to hold at a steep angle if needed. Works on the same post as our Trigger-Finger hold-down. Assembles quickly and self-aligns/levels to the correct starting point.
Post is steel and clamp lever is black anodized aluminum (thumb screw included). Can be ordered with a ¼-20 or M6 threaded post.
- fixture
fixture
